Posted by John T on May 24, 2010 at 12:23:28 from (66.244.97.31):
In Reply to: Amp Gauge Question posted by Phillip Low on May 24, 2010 at 10:49:14:
Sounds like you n Rusty have it figured out. Id simply just turn on the lights and ignition (assuming its a coil ignition) when shes NOT running and if the ammeter swings over to + charge versus - discharge as it should YEPPERS ITS WIRED BASS ACKWARDS. Such can happen if a tractor is converted from a Positive ground genny system to a Neg ground alternator and the dude forgot to reverse/swap the ammeter leads. If its a coil ignition the coil leads should have also been swapped if it was changed from Pos to Neg ground
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
