Re: moldboard
Posted by mkirsch on May 25, 2010 at 05:21:28 from (64.80.108.56):
In Reply to: moldboard posted by Paul G. in Mn on May 24, 2010 at 17:13:34:
The only moldboards available new are the Super Chief style. Those will run you about $100 each.
Anything else, you're out of luck with new parts.
Without a picture I can't be sure but I'm betting that you've got the old two-piece bottoms with the quick-change shares.
All you can do there is look for another parts plow with decent moldboards if you want to stay with the original style bottoms.
You can also replace the entire bottom assembly with the newer Super Chief style. Again, a parts plow with decent wear parts would be your best bet.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
