Been through a similar problem with an older tractor after I'd been through it and rebuilt it stem to stern and left it sit too long before painting.
You've got the right idea, but go about it the other way. From your description, you've got good brakes that will grab hard and quick. Try pulling something that will take some scuffing on the tires, another tractor, an off-road truck, whatever. Pull it ahead with your tractor, and your clutch pedal in the disengaged position, have the person in/on the towed vehicle get on their brake enough to lock it up, then start banging on your own brake pedals with the clutch pedal down. A lot will depend on your surface, the tires on both, and how hard the clutch disc is bonded to either or both the flywheel and pressure plate.
If that won't break it loose, you likely have a split coming up in your future.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
