Posted by Chas Weller on June 13, 2010 at 19:29:57 from (71.241.107.109):
It has been several weeks - tractor would not start - firing out exhaust and intake " timing problems " Exactly ! had to remove loader, remove front end plus the normal items to access the front cover of the motor. Well the nut came off the cam (must have been off for awhile the nut is in perfect condition)the cam gear finally wore all the threads off the cam, the keyway became loose enough and the gear wore the teeth off itself and the distributor drive gear. Remember when the valve cover was removed all the valves still operated and correctly. Well now I need to find a camshaft, cam drive gear with key, distributor drive gear plus the oil slinger for the front of the crankshaft; also a manifold(found badly cracked). As always thanks for the help, advice and shared years of knowledge and experience! Any suggestions as to the best source for parts?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
