Re: Installing Belt pulley on Super C
Posted by Bill Lisbon on June 18, 2010 at 18:43:47 from (69.89.162.186):
In Reply to: Installing Belt pulley on Super C posted by Hayrake25 on June 18, 2010 at 18:09:31:
The shims are used to set the gear backlash, use only enough shims to get a little, I'm not sure what they recommend. I would use the gasket and some gasket sealer.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
