Re: Super C fast Hitch
Posted by Matt896 on June 24, 2010 at 09:06:56 from (74.70.76.26):
In Reply to: Super C fast Hitch posted by Red -WI on June 24, 2010 at 05:40:52:
I believe there is a hole in the bar that runs parallel with the lift cylinder that is used to pin the draw bar into place. You can pick up and appropriate length clevis pin or just use a nut and bolt.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
