Posted by bjd on June 25, 2010 at 09:18:24 from (98.239.34.115):
when using the 3pt hitch or the remotes to lift up a load you have to throttle up to about 2000 rpms to get it to pick up anything. at and idle it will move the clyinder on the disk in and out until it starts to put weigh on the tires then have to raise engine speed to pick up 3pt will pick up my dad(250ish) while standing on it at idle fine but have to raise engine speed to pick up an old case 2 row planter. so far i have changed fluid filter and the orings on the pump and housing. swapped out the relief valve on the side of the seat with one out of a working tractor no change. dont know what else to check before changing pump do ya have any other suggestions
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
