Posted by pete 23 on July 05, 2010 at 21:30:12 from (184.12.35.20):
In Reply to: 656 hydro leak posted by calffeeder on July 05, 2010 at 19:17:46:
I can see no good reason tube would continue to cause a problem if hydro is working well. Are the tubes clamped together securely . This is a high pressure line (like 6000 psi) so any vibration would be a problem. Has to of course be the proper steel line and from what you said I am going to assume you are using oem replacement line.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
