I would replace the filter and clean the filter screen as a start. You could have a partially plugged open relief valve. Maybe the one on the block attached to the under seat rock shaft housing. Pull the cover and you can clean the sludge in the bottom as well. Go easy with a putty knife to lift the cover and you can probably save the gasket. I've had mine off a few times and reused the same gasket.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
