Re: H engine question.
Posted by Owen Aaland on July 07, 2010 at 17:16:52 from (65.161.86.20):
In Reply to: H engine question. posted by CJ_1080 on July 07, 2010 at 06:25:48:
I think what you are looking at is the drain for the oil filter. There should be an 1/8" pipe, about six inches long in that hole. The oil filter on an H is a bypass type filter. Any oil going through the filter is returned to the oil pan. The amount of oil going through the filter is metered by a small hole in the long bolt that holds the filter canister in place. If you plug the drain hole you will not have any oil flow through the filter.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
