Re: Water in tranny/diff. on M
Posted by CoopertownBob on July 12, 2010 at 07:54:37 from (74.51.5.96):
In Reply to: Water in tranny/diff. on M posted by John Athey on July 04, 2010 at 06:33:06:
Clarkbug said: (quoted from post at 10:21:46 07/04/10)
I also pulled all my deck bolts and put a neoprene washer underneath to try and help seal out any water, might be worth a try in your case.
I was going to say the same thing, as I discovered that on my '40 H, if it gets wet on the tranny cover, some of the bolt reliefs will hold water and some won't, so it has to be draining into the tranny instead.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
