Posted by mkirsch on July 22, 2010 at 12:24:30 from (64.80.108.56):
In Reply to: IH # 8 plow posted by DTK on July 22, 2010 at 06:19:08:
Yes, the bolt patterns on the beams are the same.
You can install WIDER cut bottoms on a narrower plow, but not the other way around. That is a 16" bottom will work just fine on a 14" frame.
In reality the only difference between a 16" and a 14" Super Chief is the length of the share. IH shows the same part numbers for the frog, shin, and moldboard for both bottoms.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
