Posted by smoknbs on August 02, 2010 at 16:46:56 from (97.83.75.69):
In Reply to: MD Linkage posted by David Boelman on August 02, 2010 at 15:19:29:
lever must be foward to start on gas . have lever forward and open gas , then check for gas at carb by opening bowl drain ,the check for spark , if mag ,unhook gounding wire from mag to rule out the switch on the manifold .----
anyone reading this or if you know some one with an MD , tell them to drain the carb for winter/long term storage . this spring had to put new float in beause the old cork float had the coating ate away and swelled up to the point the float was sticking to the sides of the bowl !!
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
