Posted by MRJHG on August 07, 2010 at 09:05:09 from (96.33.159.219):
UPDATE: I've visually inspected everything from the cam to the top of the piston. Nothing is touching and everything seems absolutely correct.
I let the engine idel and watched a push rod bend. After I broke everything down, I found another one was starting to bend also.
The only thing I found out of spec is my IP seems to be timed for 22 degrees BTDC instead of 14 and one manual says to lash the intake to 10 thousanths where I was lashing both to 12.
I have new push rods on the way but have no clue where to go to next.
I'm going to hate bringing this old tractor to a dealer.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
