Posted by bc on August 09, 2010 at 19:15:00 from (208.189.34.225):
In Reply to: 2500A Backhoe posted by michael w. brown on August 09, 2010 at 10:46:51:
If it is anything like my 2606, there is a popoff valve on the return line block that mounts on the right/passenger side at the front of the rockshaft housing. There is another one at the front on the right/passenger side but inside the housing under the cover under the seat.
I pulled my out of the housing and it had a piece of broken spring holding the ball open. Stuck it in the vice to open the ball and the metal piece fell inside. It is still there and been working ever since. The pockets are staked on the inside so the guts can't be unscrewed.
However mine was blocked open so there was no pressure. If you have pressure, then your problem must be something else blocked.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
