Posted by ScottyHOMEy on August 10, 2010 at 18:40:05 from (70.105.240.40):
In Reply to: Re: Resistor Block posted by farmall706 on August 09, 2010 at 20:17:51:
If you're lucky, there'll be some vestigial printing, usually in white on the black paint covering the coil housing, to indicate whether it might be a coil meant to operate on 12 v without a resitor. Lacking that, it's pot luck.
Not exactly a harm -- it won't hurt anything, but the tractor just won't run right if at all -- to run a resistor in the line ahead of a coil designed to take a 12v input. The effect of the resistor is to reduce the 12v to 6v. I don't know enough about how a coil works to say that it would be a direct reduction, but . . . you get the picture.
Worth tryin' anyway. Can't hurt. Might work if you've got the 6v coil.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
