Posted by Pete7 on August 14, 2010 at 16:36:47 from (72.65.39.49):
I have a Farmall 340 that the past owner converted from 6 volt positive ground to 12 volt negative ground. Typical conversion. But the tractor has a factory gas gauge and it wasn"t working when I bought the tractor. Pulled the sending unit from the gas tank yesterday to look at it and found the variable resistor wire had melted and burned part of the insulating board! I"m guessing the past owner sent 12 volts direct to that sending unit when he converted the electric system. Lucky the tractor didn"t start on fire. So, if you are converting a tractor"s electric system to 12 volts and it has a gas gauge, you might want to be extra careful. Pete
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
