Posted by badaugherty on August 16, 2010 at 09:49:54 from (157.142.138.244):
I just got my 300 out and mowed all day Friday. I came in and swapped out for a plow to break some ground for food plots and halfway through it started spitting and sputtering. I'd tap on the tank and it'd climb back up in RPM and I would go for a little while and it would do it again. I drove it straight to the shop, drained the gas and pulled the tank. I was so tired of fighting with rust. I spent all afternoon cleaning it out, put a chain in and rolled it around and beat on it with a rubber mallet. I washed it out, degreased it and put on a stand to dry with a blower blowing in it. On Sunday evening I plugged the drain and broke open a can of Red Kote and coated the inside of the tank. It looks like it only took a 1/2 quart to coat the tank, so I'm going to put another layer on this evening.
The rust in my tank has been a pita since I've owned it and now that I have it lined is there even a need for the sediment bowl? Won't an inline filter do a better job? I need to pick up some new fuel line and was thinking I could just get rid of the sediment bowl altogether.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
