It's possible, but not likely that the whole mainshaft is "loose". The mainshaft rear bearing is held on one side by the pinion gear and by three steel retainers on the other. If that bearing is shot you can replace it with a "max" type that has more balls than the original one and thus higher capacity.
The pilot bearing will eat a $100 bill at the dealer. Check with Steel Wheel Ranch if you end up needing one as they advertise them now and are good people.
All the other bearing in the trans and rear are standard dimension ball bearing and can be obtained online or at a bearing house. Also, although I don't remember on the pilot bearing all of the other bearing are METRIC, believe it or not. Has to do with bearing standard that were in place long before M's came along!
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
