Re: 966 vs 1066
Posted by pete 23 on August 29, 2010 at 17:30:53 from (173.87.8.216):
In Reply to: 966 vs 1066 posted by 1965lonewolf on August 29, 2010 at 15:34:31:
Could be kind of hard if he is bent on covering things up. The 966 had 12 inch clutch but could easily be changed to 14. The 9 had cat two three point hitch and 10 had cat three but there again if he has all that off the both had same rear frames. Internally, the 10 has wider bull gears and bull pinions, different bearing, and bearing end cap on outer axle. It may have a part number on it you could see from outside. Axles are different but same external size. Almost forgot, different fuel tanks, easily recognized , wouldn't think he would change them.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
