Re: Farmall Super C hard starting
Posted by Ron-MO on September 03, 2010 at 19:16:08 from (174.131.231.125):
In Reply to: Farmall Super C hard starting posted by Dean Olson on September 03, 2010 at 19:06:50:
My C does the same, and I do have a Carter on it. Problem with mine is leaky needle valve. I simply shut off fuel when I am finished, and does not cause a problem. If I forget, and let it sit for more than 20 or 30 minutes, it is hard to start, belches black until it cleans out, then it is fine.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
