on this "A" style of regulator/generator, the field terminal on the regulator is grounded internally. As the voltage rises, the ground is interupted using vibrating points. That allows a resistor to be in the ground path when the voltage opens the points, lowering but not eliminating the charge rate. Hooking voltage to the regulator F terminal from the battery (if hooked to the gen or not) will nearly instantly ruin the regulator voltage control relay/contacts. Flashing from BAT to F will ruin them. Yours seemed to have the cutout relay as a problem, I think they were bad from the get go, and you didn't ruin them. Jim
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
