Posted by IH fan on September 10, 2010 at 13:03:19 from (70.248.16.1):
In Reply to: IH 240 Steering Issues posted by John - OH on September 10, 2010 at 06:48:52:
I would check two things... the worm gear set-up in the bolster and the keyway in the steering arm. If the keyway is wallowed out, there might still be enough friction in the tapered shaft/steering arm for it to steer when steering is easy. There is a Woodruff key in the shaft/arm and easy way to check it is have someone turn the wheel and if the nut on the bottom of the shaft turns before the arm moves.... well, it shouldn't do that. If the steering shaft going into the bolster turns, but the nut on the bottom doesn't turn, it shouldn't do that either.
This is assuming it is an International and not a Farmall. Seems to be a weak point on these tractors.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
