Re: Farmall 350 Row crop
Posted by Rdandersom on September 11, 2010 at 06:38:33 from (64.235.100.62):
In Reply to: Farmall 350 Row crop posted by Dean Olson on September 07, 2010 at 14:17:52:
I started farming in the 80"s with a 300 with 350 pistons & liners.It was a great old tractor.A set of rear wheel weights make a big difference to its pulling power.I abused the old girl pulling silage wagons through mud and regularly hauled 10 tons of shelled corn plus wagons to the elevator.The 300 was a joy to plant and spray with too.I did all my tillage with a 36 plate Kewanee disc and had no trouble pulling it in the spring on untouched ground.
On the other hand it did burn more fuel than a diesel. The split between first and second gear is a little too wide (had to pick corn in first) and you may have to deal with TAitis at some point.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
