The Delco does have advance components. They can be checked (to a limited degree) by gently turning the rotor by hand, in the same direction as rotation, it should turn a few degrees against spring pressure, then when released it should spring back. Rich mixtures almost always are carburation, or air supply. Set the static timing to TDC. and check it with a timing light to assess the advance. Jim
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
