It is a common problem on older tractors, trucks, and even cars. The quick remedy on a tractor is to shut off the switch, put the tractor in gear, and rock the tractor by pushing against the rear tire. Usually you will hear a "click" from the starter, and then you are good to go. Sometimes that trick does not work, so then you get out your 3/4" wrench, loosen the bolts that hold the starter on enough so you can pull the starter back, and then you will hear the click. Tighten the bolts again and it's done. Eventually, you WILL need to replace the drive on the starter, and quite possibly split the tractor and replace the toothed ring gear on the flywheel. The ring gear is not expensive, but the work involved in getting to it can be, unless you do it yourself.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
