Hi, are the pressure plate levers worn out where the clutch release bearing contacts them or are they worn where the adjustment bolt is?
We had a 434(same clutch as 424) and the levers were worn where the head of the adjusting bolts contacted the levers. Solved the problem by turning the adjusting bolts 1/4 turn so the worn parts no longer mated.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
