More than a M because the center section is also flooded. Both sections of the tractor are filled from the triangular cover opposite the gear shifter. Oil level in the center section won't stabilize for several minutes as the oil passage is through the unshielded ball bearing on the IPTO shaft.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
