Posted by Al L. in Wisc. on October 17, 2010 at 11:05:09 from (216.226.95.81):
Late yesterday I had my new Farmall 460 running and it has been sputtering bad. I was puttsing around to use up a little gas the first owner said was over a year old. Tractor quit - good. Adding what little I had from a can, the tractor ran a little better. The evening before, I had cleaning/gapping the plugs and it ran a little better. After removing the rotor cap I see it has two chunks out of it, leaving an incomplete seal; and will need to be replaced. Then I pulled the rotor and set it up on the hood; wiped the grease off distributor top and inside badly chipped cap. When I went to start the tractor it wouldn't. Guess what I forgot to do?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
