It is a very common addition after the tractor was purchased. Possible dealer install if it is a M&W pump. or a retrofit of later components if it is IH.
It ads only the value of a live hydraulic pump (considerable for a tractor in use), but not much if anything as a collector tractor.
If it is an M&W it could be worth good money on Ebay if you decide to remove it and the power steering to make the tractor original.
Good early modifications are usually looked upon as acceptable by judges at shows, but not always.
If it is an IH pump, taking it off and replacing it with a distributor drive houlsing and front cover with the correct older mount holes would be challenging. Jim
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
