Posted by wayne in mn on October 31, 2010 at 19:49:38 from (24.179.160.246):
In Reply to: hard starting posted by 53 super H on October 30, 2010 at 20:50:59:
My son had a 6 volt starter that came with a Model A Farmall. It would barely turn the engine over. Jump with 12 volts & it worked ok. So I took it to our local starter repair facility where they turned the commutator, checked the field coils, and put a bushing in the rear cover. No difference! I helped re-test the starter at his shop and swapped parts with a known good starter. The problem was that the armature that had tested ok on the growler had some internal open or shorted windings that prevented normal operation and hadn't shown up during testing. Replaced the armature and 6 volts starts the tractor like a charm!! Remember: 6 volts was the norm for many years and performs great when the cables AND starter parts are in decent shape.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
