Posted by rustyfarmall on November 05, 2010 at 07:21:08 from (209.152.78.140):
In Reply to: start-up posted by JKYR on November 05, 2010 at 06:48:25:
You should remove the spark plugs and squirt generous amounts of automatic transmission fluid into the cylinders before you ever attempt to crank the engine. Wouldn't hurt to change the engine oil and replace the filter. Also would be a very good idea to remove the carburetor, dis-assemble, and give it a good look over and at least a quick cleaning, likewise with the fuel tank and fuel sediment bowl.
On the ignition side of it, at least remove the distributor cap, inspect it, and while it is off, take a look at the contact points. If they look OK, drag a piece of paper between the contacts to clean them up a bit. If the points look worn and corroded, replace them.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
