Posted by greyfoxxca on November 20, 2010 at 09:27:27 from (137.186.159.24):
This message is a reply to an archived post by LonM on August 07, 2010 at 19:30:20. The original subject was "Re: 210 IH Swather Coil".
a coil running fine will not be hotter than the engine. Tells me that the running voltage 14 volts is too much for it. Can you put the old coil back on and test out the operating characteristics?
most times the starter power is full voltage while starting. When running the voltage goes to 14 volts. The coils with internal resistance has a resister that as it warms up increases the resistance to keep the coil in the proper voltage range. If this resister is not working properly the coil could be overheating and breaking down. The new coil could be faulty.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
