Posted by Gene Norman on November 29, 2010 at 19:21:55 from (12.74.69.68):
Got a problem with my H since I bought it,it has a no load miss & will run correctly on a little pull or when you open throttle & about 30 seconds after you start it. a little info on what i have done, it had a cracked head, but ran same way when i bought it. had another head reconditioned,Pressure checked block, adjusted valves, rechecked clearance at least 3 times, carb. actually i have an extra carb & rebuilt both, same on both. new plugs twice now have 3116 Autolites in it, new points,condenser, wires, cap & rotor, switched dist with a buddy, no help. checked cam lobes,O.K. it has aftermarket manifold on it, i took it off & checked for internal cracks with water. seems ok. no leaks. checked around new manifold gaskets many times for leaks. Also after running a short time the 2 outside plugs are firing good, but 2 inside ones are all sutted up. Anymore ideas guys?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
