put the pto under load and try engaging with the clutch down. It might not do anything. It's normal for some transmission ptos creep (spin with clutch down) due to unavoidable friction between moving parts. try shifting gears with the clutch down too. You may find some undesirable friction is occuring if you have difficulty shifting from neutral to a gear--then the problem is the pilot bushing/bearing.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
