Posted by rustyfarmall on December 18, 2010 at 12:54:59 from (209.152.78.140):
In Reply to: light switch posted by Blackstack on December 18, 2010 at 11:07:50:
The 4 position switch was used with the cut-out relay which did not automatically regulate how much charge was being put into the battery, so if you were using the lights, the high charge position was used, and if using the tractor WITHOUT the lights, the low charge position was selected to prevent overcharging the battery and boiling it dry. I sometimes use the high charge position on my 1940 H if I will be running the tractor for only a short time, because it will more quickly replace what is lost in the battery from just starting, but the low charge position is always used when using the tractor for an extended period. The ampmeter is a good indicator of which setting to use.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
