What Weird or Unique Farmall's Have You Seen or Made?
Posted by Stephen McCoy on December 19, 2010 at 07:32:44 from (173.27.210.76):
There seems to be some interest recently in one of my projects so I thought rather than derail someone else's thread I'd start a new one.
I have a 1945 Farmall H that I put T-20 crawler tracks on with my students back during the '05-'06 school year.
third party image
To answer some questions:
The H is complete. I could take the undercarriage off at any time, put wheels back on the axles, reinstall the steering components and have the H back as it was when I purchased it.
The tractor steers by differential braking. The original T-20 control levers are mounted to the seat frame and are linked to the brakes by 3/4" steel rods. When you pull back on a lever a brake pedal can be seen moving as the brakes activate but if you step on a brake pedal no movement is transferred back to the lever. A slot in the connection prevents this.
third party image
The 2x4's mounted on the tracks are made of HDPE plastic. There are 29 of them on each side. 4 holes were bored part way through on the bottom of each to clear the track plate bolts. 2 holes are all the way through to bolt them to the track plates and each of those holes in counter-bored for the head of a carriage bolt. 464 drilling operations in all! Actually 480 since I made 2 spare blocks with remaining material.
The blocks do help to keep the tracks from tearing up the driveway and the road but do limit some of the traction in the dirt but since it really wasn't built for pulling a plow that's ok with me.
Here's a close-up of the decals I made for it.
third party image
What weird or unique conversions have you seen or made?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
