The 460 hitch has cast collars on the lift links that can be locked with a 1/2" square head set screw. They eliminates float. The Fast Hitch sockets have 3/4" pins that can be pulled to allow the socket to rotate up. I think both of these features were meant for ground engaging tools such as plows and harrows. May be helpful for a rear blade under some conditions.
The anti-sway bar also has a removable pin to allow sideways movement.
When you use the word "lock" referring to a Fast Hitch, I think about the 300-400 draft position cylinder. It can be removed (or not) and the front end of the bail can be locked up with a pin.
There may be other "locks". An operator's manual would help you set up your hitch the way you want it.
There are also socket latches but I am assuming you are not referring to those.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
