Redgems, sounds like condensation to me. One of the hardest things on an engine is short runs that don't totally bring it up to operating temp.
While I don't think that anything is amiss here, I would certainly run this puppy up to temp and keep her there for at least 30 mins. Condensation in the crankcase is NOT uncommon for tractors that don't get a regular workout. Not sure if you have some work for it to do, but I would certainly work it a bit, easy at first to run the rings and cam in, then REALLY put her to work. See if you condensation goes away.
comments on the re-tourque of the head are appropriate which of course also require checking/setting the valve lash. However, check with the machine shop that did your work to see what kind of head gasket was used. some require re-tourque, some don't. guessing is NOT the way to go here...................
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
