Sounds like one I used to have. I never could get it to work right, either would not raise high enough or not low enough. The arms going to the rockshafts would flex, and eventually broke one, so I replaced with a length of chain which seemed to work better, but still not very good. Also, I had to remove the drawbar to use 3 point, and vice versa. I eventually removed, then sold when I decided it was more trouble than it was worth, and I had two other 3 point tractors anynow. I do like the looks of the saginaw 3 point hitch, but didn't like well enough to part with that many $$. I would rather put a fast hitch on it, and then a converter for the fast hitch if I were to try again.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
