Jim is spot on about the graphite-block bearing. I know I encountered one on my SuperC and, from what I read about the two kinds and the number of posts on here, it may have been the more common bearing.
IH listed the more conventional bearing and its carrier as optional with the Hydra-Creeper unit. For that unit to operate required blocking down the clutch pedal (other optional parts accomplished that) so that a hydraulic motor could backfeed into the transmission through the brake shafts. It may have been a fine bearing for day-to-day use moving a tractor around, but the graphite-block bearing would not have held up under that kind of use.
The carrier is still available from Case IH. It comes dear, but my view on dealer parts of that sort is that it can't be cheap to supply and stock unique parts such as that for 60-year-old tractors. The bearing can be got for less elsewhere, but for a project like that, I'd probably pay IH's price for the bearing as part of the same purchase. The separate profit on the bearing is the kind of thing that encourages/allows the company and the dealers to keep supplying them.
Yours is pretty much shot. If it's any comfort, I had to replace a perfectly serviceable one when I overhauled mine. From the time the graphite bearings are new, the clutch fingers find a home and wear into the face of the graphite. Works well as long as it's all worn in. Removing and putting back as I did, the line up was off from where it had been worn in over the years and the fingers ripped chunks out of the edge of the ggraphite, enough so that I had to resplit and replace it with the carrier and separate bearing.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
