Posted by Bob M on January 12, 2011 at 12:12:58 from (67.240.171.41):
In Reply to: manifold moisture.. posted by mike paulson on January 12, 2011 at 09:34:48:
Mike - So long as you have an exhaust stack flapper to keep rain/snow out, any moisture in the exhaust comes from exhaust condensation. As the engine warms as the manifold temp exceeds 212 deg the condensation will cease. And any moisture left inside will quickly flash off.
Regarding drilling a manifold drain hole: DON'T!
I've had the "pleasure" of running both a tractor and a stationary power unit with owner-installed manifold drain holes. The drains caused constant, annoying "bird chirp" sound whenever the engines were running. Also blast from the cooling fans caused exhaust fumes to be blown directly back onto the operator. Not good!
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
