Re: Serial numbers Super C
Posted by Jim Becker on January 16, 2011 at 11:08:55 from (173.74.120.16):
In Reply to: Serial numbers Super C posted by Joe P. on January 14, 2011 at 03:02:22:
That explains a lot. Both tractors have had some parts swaps.
Serial 165550 was built 3/53. So all these date codes: HYD 2 27 Y, CENTER 2 18 Y, REAR 2 21 Y (all in February) fit. However, MOTOR 11 30 Y was cast the following November. At SOME POINT the engine (at least the block) has been replaced.
Serial 175164 was built 6/53. Both of these date codes: CENTER 6 16 Y, REAR 5 8 Y (June and May) are reasonable. However, MOTOR 1 15 Z was cast the following January. Same deal as your earlier tractor. Your engine number (3021) only makes sense if you missed a couple digits. Sometimes they aren't stamped to heavily and can be easy to miss. Given the date code, the whole number might be 203021, which would have been assembled about March or April.
The date code of HYD 8 9 W dates back to August 1951. It is unlikely that it sat in a corner of the factory for nearly 2 years before it got bolted to a tractor. So it was probably put on your tractor as a used unit at some later date.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
