Posted by wayne in mn on January 19, 2011 at 19:31:11 from (24.179.171.87):
In Reply to: Super C Stalls posted by Scott Bardman on January 19, 2011 at 18:20:18:
With the engine cold, pull the coil wire out of the distributor cap & hold about 1/4" from a metal surface. Turn the switch on and crank the engine. You should see a bright blue spark. If it is weak & yellowish you have an ignition problem. Repeat when the engine stalls to see if there is a difference. 3 things are needed to run an engine; strong timed spark, burnable fuel mixture, and decent compression. When the engine quits or won't start, look for the missing item.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
