Posted by sflem849 on January 26, 2011 at 04:00:53 from (69.197.84.192):
In Reply to: locked up H posted by jbuckshot on January 25, 2011 at 18:28:27:
neblinc said: (quoted from post at 08:29:12 08/26/09) Most likely your shifter lever is worn, not that hard of a fix.
There is a pin that holds the lever to the casting that needs to be removed. Some will have metal caps to keep the pin in place, some can be pried off, otherwise just drive a punch into one side and the other side will pop off.
Your shifter should look like the pic below, if not, it will need to be built up.
Randy
This post was edited by sflem849 at 04:01:25 01/26/11.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
