Posted by Zachary Hoyt on January 26, 2011 at 05:29:49 from (184.12.74.215):
In Reply to: tire chains posted by wilber on January 26, 2011 at 04:42:21:
I think you might be a little short if you have 11.2 tires, but if you have small tires I would think you might be fine. It also could depend on how much tread the tires have and what type of chains. One easy way to estimate is to take a 20" piece or string and lay it over the tire so it hangs down evenly on both sides and measure from the end of the string to the edge of the rim. Multiply by two and add 26 for the rim and that gives you the diameter of the circle the side of the chain needs to make. Zach
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
