Chances are that the blind threaded insert is good. The leak is probably coming from the joint between the insert and the tank sheet metal.
Another possibility is that the tank sheet metal has stress fractures. If the rubber washers and springs were not installed properly, vibrations might have weakened the area around the insert.
The leak can be fixed but you might give some thought to getting another tank. That's what I would do. Do you want to live with a leaky tank, or worse, apply heat to repair it.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
