Posted by Paul f on February 09, 2011 at 14:04:12 from (206.158.36.249):
I am working on a friends C whose PTO died. I got it apart and it is apparently not the first time it has broken. Some previous owner welded the PTO gear to the PTO stub shaft. That weld has failed...but the gear doesn't want to come off the shaft. Also please note the hammer dents in the gear itself, I didn't do that!!!
Is there any reason I cannot push the shaft(with the gear) from the housing from the outside??
If he can't afford a replacement shaft and gear thoughts on re-welding it???
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
