If I'm reading your question correctly, the IH manual refers to that as "where the valve lever contacts the valve stem contact," so it doesn't really have a name. It is not an insert, but that surface is hardened. It will wear, but a machine shop can resurface it, as long as there is enough hardened material there to work with.
As far as getting a blade in there, it needs to be a narrow one, as close to the width of the valve stem as you can manage. The surface of the arm is intentionally cupped -- the valve stem moves in a straight line while the arm moves on an arc, and it's that cup that keeps the pressure on the valve stem straight up and down.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
