Posted by WSJ on February 17, 2011 at 17:24:12 from (216.139.17.182):
Any constructive remarks about the following idea would be appreciated.
I wanted to add a voltage gauge and a tachometer to my H using one gauge mounting hole. A multifunction circuit could be designed to display several engine functions using a single tachometer as the display device. Any 12 Volt digital or analog tachometer may be used to display RPM or Voltage in a 6 or 12 volt system. Additional functions can be added such as; oil pressure, oil temperature, air temperature, speed or charging current. A function selector switch could be mounted in any location.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
